Topic: 5.0 Intake Gasket (Read 1245 times) previous topic - next topic
5.0 Intake Gasket
Is there supposed to be any sort of gasket between the upper manifold and lower on a 86-88 302 FI?
Books I read say yes, but personally, I have never seen one.
If so.. will not having one effect anything?
Thanks
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
5.0 Intake Gasket
Yes,there's a gasket that goes between the upper and lower.No sealant,just the gasket.without it,vacuum leaks.
5.0 Intake Gasket
^not always, vin.  my buddy has a built mustang and it has no gasket there, and no problems.  I personally use it but have used only one gasket before when I swapped in a spacer.
5.0 Intake Gasket
...and maybe he's got an aftermarket intake with machined surfaces, perhaps?
Even then, I'd use one.  You'd be surprised how bad the vacuum leaks could be on an upper that's been pulled a few times and has no gasket.
5.0 Intake Gasket
I've run my Cobra upper without a gasket... It did idle a bit high, so no doubt had some vac leak... Still with re-set idle, I couldn't tell any difference in operation...
5.0 Intake Gasket
I have a built cougar I use them.
5.0 Intake Gasket
Thanks..
 I'll be installing one. Just wish I would have done it while I had the fugger apart a few weeks ago.:punchballs:
I have ran without one on my Cobra intake on my 92'. I guess the intake your using makes a difference.
