Topic: 88 XR-7 Driverside Fender wiring diagram needed (Read 1032 times) previous topic - next topic
I need the diagram, hopefully within the next few hours....
Can anyone help me out...?
So what are you looking for? The diagram of the wires running on the inside fender area? That can't be to many. Lets see. You'd have CC wiring, horn, windshield washer pump, wash level. That should be it. The cruise wires should run through the same hole as the vac line for the CC. Then you have the washer pump, and level sensor. Those enter the fender through the hole where you fill the wash fluid. I think the horn comes around from the front with the light wiring. I've got the EVTM on disk but can locate it at this min. That and I'm on lunch so I have to head back in a few.
