Topic: valve covers (Read 1711 times) previous topic - next topic
valve covers
dose anyone know how hard it is to put new seals on valve covers and what do i have to take off to do it
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
valve covers
Pull the upper intake,remove the 6 bolts from each valve cover,remove the valve covers,clean the mating surfaces of the valve covers and the heads really good,purchase new rubber valve cover gaskets,place them on the heads,place the valve covers on top of the gaskets,bolts them down (it doesn't take much to torque them down),re-install the upper intake,done.
valve covers
is their a patern to bolt down the valve covers
:birdsmily:
valve covers
I'm sure there is.I just start from the middle and work my way out.Snug them,then tighten them.There's only 6 per side.
valve covers
oops.. I went with cork..:toilet:
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
valve covers
The rubber ones are really nice,reuseable,and seal great with no sealer.
valve covers
CORK SUCK
this is a simple job
best off throwing a thin bead of sealer on it to be safe
and watch wireing connectors and vacuum lines!!
valve covers
Meh I've used cork Felpros with no leaks for years :mullet:
valve covers
all ive ever used is cork.
rubber is nice, but cork to me is the only way to go
valve covers
Is there any difference between Carb and EFI valve covers?
valve covers
Yes,there's a difference in the covers,but the gaskets are the same.
valve covers
Well.. I used the permatex gasket seal maker on both sides of the gasket. I guess time will tell.:D
