Topic: need help (Read 2067 times) previous topic - next topic
need help
what is the best thang to get oil off my motor?
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
need help
elbow grease.
Get some of the purple cleaner from O'Reilly's. Spray it on, let sit and rinse off.
need help
Purple power by Castrol, (Dillute it to about 3-1 ratio first, its nasty) or a 50-50 simple green and water mix.
88 TC, Lots of Mods.
need help
i went to autozone and got some of this fomey stuff and its seems to work good for only cost $3 a can
:birdsmily:
need help
spray on oven cleaner, cheaper than the auto store can stuff that does the same thing.
need help
o cool thanks for telling me
:birdsmily:
need help
i use castrol
straight up it takes off EVERYTHING
need help
Quote from: Ductape91;221690
yes spray oven cleaner will take all the grease off the engine.
but will take all the paint off the engine with it..;) if you plan to repaint the the whole engine then great but other wise just use a good engine degreaser like foamy gunk.. the trick to useing foamy gunk is get the engine warm not hot then spray everything down and let it sit for like 10 minutes then pressure wash it all off. just make sure you cover the distributor with a small plastic bag or you will have tons  of fun trying to get the engine started again.. the inside of the distributor will be soaked.
Nick
need help
I used to use the gunk stuff and a pressure washer
need help
im useing foamy gunk stuff i just spriyed it for the night and im going to let is sit for the night
:birdsmily:
need help
i dont have a pressure washer tho so i just have to use a hose
:birdsmily:
need help
get one of those high pressure hose nozzles.
need help
ya i did the vale cover and it cam clean preaty easy
:birdsmily:
need help
Did you find a car?
need help
im look at a tc right now just wating for the guy to send me some pic of the car becaues it an hour from me
:birdsmily:
