Topic: More work done (Read 832 times) previous topic - next topic
More work done
Did the valve cover gaskets and removed the air silencer on the Cougar yesterday. Slow but steady progress.:burnout:
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
More work done
Cool which valve cover gaskets did you use? I always had problems with valve cover gaskets till I went with that rubber coated steal gasket.
More work done
Just went with the Felpro cork. Seems to have done the job for now.
More work done
Hopefully the cork hold for you. If you do the job again check out the rubber steal gasket, its reusable too :)
