Topic: aod to c4 swap (Read 1175 times) previous topic - next topic
aod to c4 swap
hi
the aod is going bad so i want swap to a c4
What do i need to do and what parts do i need for this swap?
I got a c4 (panfill) that shifts great. it has the big bellhousing.
Will driveshaft and crossmember fit and what about kickdown wire/rod?
Sorry for many questions, but here in norway its not easy to just take trip to the junkyard for parts. (probably only 10-15 tbirds over here)
Any help is appreciated
aod to c4 swap
Not sure but I believe the converter will bolt to your existing flexplate... If not, you can't use earlier than a '81 flexplate cause engine balance changed from '80 to '81... Overall length and trans mount should be the same, measure to be sure...
For the kick down linkage I don't know, but a C4 operates with no ill effects without it, as it only shifts the trans back to second... The vac modulator controls the part throttle shift/firmness...
aod to c4 swap
ok thanks. i`ll take some measures of the trans. Can i use the column shifter with the c4? or must i change to an aftermarked shifter.
Thor
aod to c4 swap
Yes, the column shifter will work with the C4
