Topic: Headlight adjustment (Read 793 times) previous topic - next topic
Does anyone know how to adjust our headlights? I recently polished mine and the look semi-clear. Driving down the street tonight i noticed my high beams light up halfway up the trees. I feel after the cleaning they should throw more light than they used to when they were yellow. Anyone have any ideas? I'm desperate. Its quite the challenge to see at night.
John
there are 2 screws on each h/l with a 4mm hex. find a level
spot about 25 ft away from something like a garage door.
1 screw will raise or lower each lamp, the other will make
it go side to side. put a towel over the other lamp to block it
off. you can take it down the road and see how you like
it. oh, by the way, you will be doing this after dark. or you
can take it to a body shop and they will charge you to
align the lamps.--irv
