Topic: AOD Trans Questions........ (Read 2376 times) previous topic - next topic
It's been a while since I messed with an AOD.........
It's an 83 Cat with a 5.0 and the AOD.    Column Shift, and about 120k on the AOD.
The car doesn't seem to go into the P position completely.    Meaning, that it does slightly go into park, but if on an incline, it will pop out of P and roll.    This happens weather the car is running or not.
Also, when driving at highway speed, before the trans will kick into OD,  I have to lift my foot off the pedal, then it kicks it into OD and all is well.
Other than this, the AOD behaves quite well and has no issues.
It's done this for a little while now and I'm finally trying to figure it out.    Does this sound like just a TV Cable Adjustment?
Fluid/Filter were changed about 800 miles ago, pretty routine service.    Nothing smelled/appeared burnt.    Everything looked in good shape from that point of veiw.    The AOD behaved this way before the fluid/filter change too.
PNRD21 indicators (instrument panel) do not line up.  (can't imagine this would be relative to the AOD issue however)
Any thoughts folks?
To laugh often and much; To win the respect of intelligent people and the affection of children; To earn the appreciation of honest critics and endure the betrayal of false friends; To appreciate beauty, to find the best in others; To leave the world a bit better, whether by a healthy child, a garden patch, or a redeemed social condition; To know that even one life has breathed easier because you have lived. This is to have succeeded.
]Ralph Waldo Emerson
Quote from: zane;220869
Any thoughts folks?
That's a dead give away... Adj the manual(selector) linkage, will fix your inability to fully engage park as well...
Likely the O/D problem is the TV cable/linkage adj...
good advice
Quote from: TurboCoupe50;220873
should fix it.
Thanks for the suggestions!
I'll give it a whirl tomorrow and see what happens!
X3
I've had the same problems since I started driving my car only a few times a year. Things tend to get a little out of whack if they start to rust and don't move freely. I just had free up mine again 2 days ago.
You just need a little adjusting to get the selector to match up
just to add, if and when you do line up the selector linkage and your indicators still dont match up the plastic ring that holds the indicator to the steering colum may have broke.
http://www.coolcats.net/tech/troubleshooting/indicator.html
PNRD21 is this an AOD selector? Shouldn't it be PNRDD1?
Quote from: softtouch;221027
No it's: PRN"DD1
