Topic: Stalling problem (Read 955 times) previous topic - next topic
Stalling problem
When I got out to my car after its been sitting for a while and crank it over, it cranks over 5-6 times, starts and the immediatly dies. However if i give it some gas right after is starts it usually will stay running.  If i try and start it again, it starts first crank, and idles high as it should. Anyone have any ideas on what could cause this?
I thought fuel injection was supposed to cure problems like this. :(
John
Stalling problem
Computer codes?
Stalling problem
This is the '88 3.8 T-Bird correct?
First thing would be to check if there are any error codes like already mentioned. There's info on how to check them in this thread
You can do a quick visual check to make sure all of your vacuum hoses are intact and not cracked or broken as that can cause the car to stall on initial start-up. I had a similar problem with my car stalling on it's first start-up and it was a rubber hose that was split.
