Topic: compression ratio ? (Read 2420 times) previous topic - next topic
compression ratio ?
hopefully the headers and dualsgo on tomorrow.
factory shorties, walker hpipe,super turbos, but
88 cougar tailpipes [already on]. will see what
happens.
compression ratio ?
Quote from: kitzdnm;220054
You probably will have to extend the o2's,you can splice your own wire to them to make them longer,
DO NOT extend the wires on the O2 sensor wire as they are a special wire and extending them can cause problems. Extend the wires that are part of the engine harness as then it doesnt matter.
compression ratio ?
o2's work off resistance. splicing a wire adds resistance through buttconectors, solder and stuff like that. just get an extension kit, its made to have as little effect on ohms as it can. besides, if you do cut those wires and it turns out your splicing did make a difference, those o2's are gone forever. thats more money then a simple kit.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
compression ratio ?
Bosch makes O2 sensors with longer wires for our applications.  Those are what I use.
compression ratio ?
just got the bosch sensors fri and the bbk extensions.
youre right . i sent the extensions back. friend started
on the headers yesterday. glad i didnt try it at the shop.
he has  a large 2 post lift. the words were flying about
hooking up the h pipe. i had a t5 hangar. ended up
using the stock one instead. had to leave for grandsons
ballgame so i havent seen how far it got fri.
compression ratio ?
Quote from: grutinator;220148
Not so... Unlike the other engine sensors, o2 sensor produce a small voltage(approx .5 to 1v)... IF the resistance of the circuit were high enough operation could be impaired, but a std but connector will not cause a problem...
This said I don't recommend those for any circuit, as over time they will likely cause a problem... I cut, solder, and heat shrink all my connections(including my reworked o2 harness)...
compression ratio ?
i coulda swore thats what they taught me at tech school. like two electrodes and the abilty of the electricity to make the jump depended on the atmospheric conditions inside the pipe. i guess i need to go back to school. how would it produce its own electricy?
