Topic: engine pics (Read 4726 times) previous topic - next topic
engine pics
OKay,
I've posted a few times about my ongoing T-Bird project, and now lack of the 'Bird part....
So I finally took a couple pics of the engine and will make my first ever attempt to post pics.
Sorry for all the junk in the background. Later I'll finish some stuff I need to do and roll it outside for a new pic.
I hope this works...
engine pics
shiznit!!!! I just creamed on my keyboard and ruined it...
That's sweet...
engine pics
It ought to be better than the stock 5.0 that I had.
engine pics
Ummmmmmmm............WOW !!!!!
engine pics
Wicked....makes me make "rumble rumble rumble" noises just looking at it.
engine pics
I'm with you Tom.......All the keys are stuck together now.
Wow!!!! I love the NASCAR theme.
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
engine pics
that motors purdy!!!:bowdown: is it a cleveland
engine pics
I got the short-block(Block, crank, pistons, rods) from Cale Yarborough's team before it folded. The heads, intake, magnesium front cover, pulleys, brackets, 5-stage oil pump and 130amp alternator from Ernie Elliott. The stainless headers from Robert Yates Racing. I'll be using a Richmond RoadRace 5 speed, no overdrive. Aluminum flywheel and the clutch has an aluminum pressure plate. Both have steel friction faces. The intake manifold is dry, as the water is run out the front of the heads through the #16 fittings seen in the pics. The lifter valley is sealed with an aluminum pan, so I can easily remove the intake without messing with any seals or silicone.
It has a small CompCams roller cam instead of the solid lifter the Cup guys are required to use. Only 12-1 compression.
Ernie told me to watch the power curve on the dyno, but don't be afraid to turn it 9500rpm. He built one nearly identical for one of the Atlanta Braves baseball players and it made 725hp, but my carb is better. But I'll be using a different dyno too.
We'll see.
I started building up another 302, and was hoping for 350-400hp. But I sort of stumbled into some deals on these parts and the project snowballed.
I still have a few things to finish on the motor. I still need to double-check the starter clearance on the oil pan. I had to flip the Tilton starter to clear the headers, and had to notch the kickout on the pan. So if everything clears now, I have to recoat the pan. ARP doesn't make a bolt or stud kit to fit this timing cover, so I have studs made from Allthread to send them as patterns. And I want to try and fit an AC compressor in front of the passenger side head.
I'm still trying to decide whether to use the motor mounts pictured, or build a front block plate. I recently added "wings" to the bellhousing to act as a rear mount. I also modified the bellhousing and block plate so that I don't have to un-bolt the starter to pull the transmission. I'll have a quick-connect on the clutch hydraulic line.
I'm always open to thoughts and suggestions from others too.
engine pics
holy shiznit
what is is??
i can tell its a ford but how many ci?
my brain is saying over 429
engine pics
Ford Nascar 351W-style block, Yates 351C-style heads.
Typical stuff, nothing special, just detuned.
engine pics
nice to see some pics of it! looks sweet.
hope you get a bird to put it in soon.
engine pics
My buddy has a yates motor out of a winston cup car that he put in his mustang, he is looking to see the 8's in it. I will get some pictures
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
engine pics
I'd put it in a Fairmont futura. baby blue in color with the ugliest hubcaps imagineable.
 I assume it's not a street car, lol.  Looks sweet!
1987 TC
engine pics
I intend for the Bird this goes into someday to be a streetcar. It might be much for rainy weather or to call it a "Daily Driver", but I have to set some mental limits to keep from building an all-out roadrace racecar. I don't have a budget to race, and the open track and HPDEs all require "streetcars". This way I can still take it to cruise nights, run errands, make a drive through the mountains, etc.
I'm trying to keep it so that almost anyone could climb in and drive it. I could have put a crazy camshaft in, 3 disc clutch, and nobody could drive it.
engine pics
Sweet a Clevor :D
