Topic: changing to Black!!!! (Read 2875 times) previous topic - next topic
Quote from: 347Thunder;216942
did you do your dash I am a little worried about the durability ans sun fading.
what did you use to dye it?
dupli-colors is what I will use not at that point yet
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I did do the dash. In fact I pulled the old cracked red dash out, painted the uncracked blue dash that was in the back seat of the parts TC when I bought it black (using the same Duplicolor stuff you used), and installed it long ago. I did the console too. Pics:
1) Before
2) During (I also rewired the ignition switch to use relays so the current for the accessories isn't carried by the switch anymore)
3) After
 that looks sweeeeeeeeeeet I can't wait to do mine
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Yeah, I like it. Once you go black you never go back, you know ;)
You'll have to forgive the dust covering everything. The car was in the middle of a bunch of bodywork at the time. As for all the  on the floor - it was from where a squirrel had built a nest in my blower fan. I'm ashamed to admit that the pile of yellow insulation is still there :(
Quote from: Thunder Chicken;217179
Yeah, I like it. Once you go black you never go back, you know ;) :(
Thats just nasty!!!
Hey is that the semi-gloss or flat paint on the dash?
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
