Topic: 3g alternator help? (Read 1161 times) previous topic - next topic
3g alternator help?
ok i did the alternator swap yesterday i did everything like the wiring diagrams say. i wired up the green wire to the external regulator green wire. the orange and blue wire to the external regulator orange and blue wire. then the brown and orange to the red post on the alternator with the big yellow wire. the big yellow wire then wire up to the positive side of the starter solenoid. i then left the white and black wire and yellow and whiter wire left those to the old external wiring harness. then i started my cougar and the volts stay at 11.5 volts all day long and the alternator only charges at 12.5 volts and also the battery amp light stays on. that is how i wired everything up. what do i do to get the amp light to go off and get the charging of the alternator to work? P.S i got the alternator off of a ford taurus 94 or 95.
3g alternator help?
Quote from: blackcougar71;216287
It doesn't sound like you followed the directions very well then.
Look at posts #49 and #50 in this thread...
http://www.foxtbirdcougarforums.com/showthread.php?p=179687#post179687
You have to REMOVE the old external regulator.  When you do, all you will be left with is the green wire.  Everything else comes out with the reg and the old alternator.
The diagrams put it out there pretty easily and the pre-87, ext-regulated cars are pretty much a cakewalk.
You need to take a couple pics of how you have this wired, because it sounds all FUBAR'ed to me.
3g alternator help?
thanks chuck i looked at the diagram on post 50 then wired it up that way it work perfect after that.
3g alternator help?
Coolio...
