Topic: 17x10.5 wheel fitment (Read 3224 times) previous topic - next topic
If I converted the rear to 5 lug,removed the quad shocks,would 17x10.5 wheels fit on the car,or do I need spacers,etc?Just thinking about some wicked tires on the back.
I had 16"x10"s in the back, no quads, and could still get my fist between the tire and inner fender. But I did have the lip rolled. I had a wider aftermarket rearend. I plan to put 18"x12"s under the new car. Unless your's is very different from my 87 sport, you should be fine if you get your spacing correct.
I'd be using a TC rear,Explorer axles and brakes.Does that change anything?
It depends on how wide the rear will be, and what wheels you are using. I can't help with that, just tell you physically what room there is in the wheelwell, based on my experience. I had custom Simmons 3pc wheels made, and the 9"rear was 2" wider per side on purpose.
I wish I could get 12" wide wheels in the front....
I just want some mass produced 10.5 Cobra R wheels with the lip on the m.that's about it.
There was a member here a while back that had a white '83 that he used 10's on the back.  I think he used the narrower Fox Mustang (Ranger) axles though.
(46TBird perhaps?)
You should remember!  You've posted in it:
http://foxtbirdcougarforums.com/showthread.php?t=15098&page=7
1988 Thunderbird Turbo Coupe
Cool. Thats what I want on 12"s. Personally I think they are too wide for 10"s. But that is another discussion...
Verification 315s fit. Woohoo!
Now in the front.......
Wow,those were big tires.It appears i have more thinking to do.
You just want cobras did you have any other ideas for rims?
Whatever you do i am sure as long as they wheels and tires fit it will look Badass.
I like the Cobra R wheels,although they are used on a LOT of Fox body cars.They fit my needs and they will fit the car after paint.Oh,and yes,the car WILL look bada$$ when I'm finished.
See what I mean,It never ends!!
Kitz,I'm glad you're not around when I cut myself working on the car,you'd be rubbing salt in the wound.LOL.
Or at least lol at you!! you no what I mean.
Yep,I do know what you mean.I am trying to get the bodywork finished and let everything else go for a while.I have so much going on with the car,nothing is really getting done.I will probably do a 5 lug upgrade later on.I have an extra TC rear with 3.55's out back,and it can be worked at any time.Right now,I'm going to focus on the paint for the car.I'm tired of looking at 5 different colors.It's giving me a headache.
