Topic: sparky, PULLING CODES AND BLEW UP THE COMPUTER (SOLVED) (Read 1080 times) previous topic - next topic
so i prepare to pull my codes.
I install a paperclip jumper wire
next i connect my 12v test light bulb to the  pos battery
next i go to connect the other end of the test light to the 6 pin connector
opps,, i bumped my jumper wire with my pos 12v test light.,,spark!:mad:
20th anny starts up and stumbles falling flat on its face.  This puts the car in the "down" status.
I figured out what happend and replaced the required part,, any takers?
The car runs now.
Lesson learned,,,,,,,,,,
Connect the test light to the 6 pin connector first then connect the other end to the pos battery post.
Blew a fuse?
nope...
the single wire connector for pulling codes is tan/light green.
time to pull out my EVTM i guess!
fuel pump relay
your at the correct intersection but wrong direction.
Electronic control assembly is were it runs to then. So its either that, or that runs to the ignition switch, and ignition module. Thats everything I can see
This EVTM is useful!!
Quote from: daboss351;215931
yep,
simply pulling my codes,, i blew up my computer.
Found one out of an 88xr7 and its up and running now.
