Topic: efi fuel pump question (Read 2222 times) previous topic - next topic
can i use the in-tank efi pump on a carb if i regulate it? i want the cleaner install of an in tank fuel pump. any help is appreciated.
Re: efi fuel pump question
Isn't a pump from a carbed 5.0 HO (say early 85?) an in tank setup?
Quote from: darkthunder
Yes you can. Just use a regulater, like the Holley one, works great. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
if your starting off with an old bosch in the tank, you have a good start.  Some of the rangers and older model subaru's had a fuel pump on the rail of the car as a secondary.
just tweek it down to about 19psi there about., give or take depending on what you feel is best.
When I ran a carb on my old '86 Cougar, I set the pressure around 8-10 for the holley. Much more than that would lift the needles off thier seats. :D
sweet! i should go grab that tank i saw at the junkyard then. looked brand new. thanks a bunch guys. ^_^
