Topic: P71 injectors? (Read 1213 times) previous topic - next topic
P71 injectors?
how big are the injectors out of the cop cars? I grabbed the 4 that were left when i was at the yard last but i dont know what size they are.
P71 injectors?
AFIK 19lb...
P71 injectors?
You're not thinking of tryin' to out run a cop, are you? :hick:
Just remember... they usually have a buddy or two to back 'em up....
:burnout:
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
P71 injectors?
Quote from: TurboCoupe50;215294
AFIK 19lb...
Really? i figured they were bigger. they are totally black if that helps.
P71 injectors?
Pretty sure they are 19lb. also.
1988 Turbo Coupe
Coming soon to NMRA Drag Radial... :burnout:
P71 injectors?
Most EV-6/EV-14 injectors are black nowadays.....The part # should be stamped on it somewhere....
P71 injectors?
Quote from: cougarXLS;215297
:burnout:
You might out run the cop but I highly doubt you could outrun his radio....
:ford::oldcougar::mercury:
P71 injectors?
Quote from: cougar1car;215333
Hence his/hers buddies!!!
:burnout:
P71 injectors?
I dunno, let me go out into the driveway and check!
19#s
:hick:
