Topic: Urgent ,i need help PLS....i need new axle shafts? (Read 2407 times) previous topic - next topic
Hey guys, topday i pulled of the axle shaft with my mechanic ,becoz the bearings are gone.......and when we removed the shaft, it was chaffed pretty bad from the bad bearings.......i need new axles....do u know where can i get them from......as fast as possible.....ford dealer here said they have em but i need to order them, but i bet theyre pretty  expensive.....so any info on where to get it would be greatly appreciated thanks guys for your help!
Blackwidow
Re: Urgent ,i need help PLS....i need new axle shafts?
Junkyard is about your only choice. You can have your existing axles "sleeved" though - any truck shop should be able to do it
btw, do u know whats the dimensions and other info on the axle...........like is mine definatley a 7.5" coz it looks like it......and is mine 29.25" length or 30"......any other info would help....like whats the OEM part number on it? does anybody know...thnks
er...i THINK the 7.5" axles and the 8.8" axles interchange.
~John~
Yes,the axles are interchangeable.I have a set you can have for $20 plus shipping.I have a rear end from my '88 that I pulled to install the locker rear.Let me know,and I'll step out to the garage and pull them for you and get them boxed up.
