Topic: Wont start with key? (Read 3118 times) previous topic - next topic
I've finished my motor and gotten the transmission pretty much ready to go. However, I'm not able to get the car to crank over with the key. If I pop it at the solenoid it works fine as long as the key is in the run position.
I checked the f usable links, ground, ignition switch, solenoid, and neutral safety switch.\\I'm runing out of idea's here... There is no power going to the top wire on the solenoid. Even while the key is in the crank position.
Also, anyone have any idea if any 5.0's had a metal fan that would work with an 87 thunderbird? The one I have now is badly cracked, and most at the junk yard don't look much better.
It still could be the ignition switch in the column.Mine had those same issues.
clutch switch?
1988 Thunderbird Turbo Coupe
Have yer got the fusible links on the right side of the solenoid? They should be on the side closest to the battery.
Ye'll need a test light to go any further. First check the big yeller wires at the ignition switch for power. They should be hot at all times, if not you've either got a bad fusible link or they're not on the solenoid correctly. If they do have power, check the red wire with light blue stripe at the ignition switch for power when the key is in "start". If it doesn't have power the switch or connector is fvcked. If it does have power, check at the solenoid. If there's no power there but power at the ignition switch the problem is somewhere in between, likely the neutral safety switch or its connections. Try holding the key in "START" while wiggling the shifter around. Also try starting with the car in neutral rather than park.
If the lamp out warning lights come on in "start" you have gotten through the ignition switch and the neutral safety switch OK, and connector wise you are out from under the car.
Quote from: Thunder Chicken;215092
checked all the fusible links that had a plug on them right nect to the battery. They all worked.
I took the ignition switch out and cleaned it. It looked brand new and all of the positions flipped in and out.
I switched out the solenoid. I wired it up the exact same way as the old one, and it also started fine before I swapped out the motor and wasn't disturbed.
I took the neutral saftey switch completely out and manually shifted the trans into park and neutral at the trans. I tried both pushing down on and letting out the neutral saftey switch.
Are there any relay's inbetween that I could switch out? Is it possible that I left a wire unplugged?
I am able to get it to start by jumping the top little red wire on the positive battery cable as long as the key is in run mode.
Thunder Chicken, I'll check the wires you mentioned when I work on my car this weekend. I can't wait to get it running.
I've got a brand new bottom end rebuild as a 87 mustang gt block with all brand new gaskets with stock tbird top end, and a junkyard v-6 auto tranny. If all goes well, I'll have it going in a week or two:burnout:
Also, the red little wire at the top of the solenoid has no power to it even when I'm trying to crank it. Its gotta be somewhere inbetween the key and the solinoid, or I guess it could still be a bad fusible link. The ignition switch, I am fairly sure works. If I dont come up with any better idea's by next week, I'm going to go ahead and throw a new one in just for kicks.
Quote from: softtouch;215134
Do you mean the "Bulb check" mode of the ignition switch? If so, it's a different circuit and unrelated to the actual "start" circuit.
Quote from: Haystack;215139
No point in replacing the switch if it's bad, and the only way to see if it's bad is to test for power at the red/blue wire I mentioned, right at the switch.
Quote from: Thunder Chicken;215195
It does test the bulbs, but not directly. It causes the lamp out warning module to turn on the lights.
Yes it is the same circuit that goes to the starter relay.
This was a optional feature for 84, don't know if all 87's have it or not.
i'll let you know today possibly if the red/blue wire has any power...
I was having issues like this for about 2 weeks. Narrowed it down between the neutral safety switch and the solenoid, so I inspected the wiring finally and the harness was royally screwed... old plastic cracking and all. salvaged it and all is good now. Basically, what I'm saying, is don't assume the wiring is fine.
