Topic: Two Issue Driving Me NUTS!!! (Read 820 times) previous topic - next topic
1)  My coolant hoses seem to loosen about once a week.
    Have new hoses (old clamps -- stainless screw type).
    Hose clamps torqued to 25-30 inch lbs weekly.
    NET Search indicated use either:
    a)  Oetiker Constant Tension Clamps, or
    b)  Plastic Shrink Band Clamps
    Anyone tried either of the above?
2)  Oil Pan Bolt leakage.  Have tried solid brass washer, and solid brass with rubber insert, still get leakage.
    Ford makes a replacement bolt with a rubber "O" ring.
    Anyone tried it and had good luck?
    Someone also recommended to try a Chrysler Pan bolt that has
    silicon on bolt face that touches the pan?
Thanks
David
