Topic: 83 cat not getting spark (Read 1649 times) previous topic - next topic
Alright, the cat left me stranded at work a couple days ago.. and i traced it down to not having any spark.
i changed the coil
i changed the ICM... california emission special to that also!
 Im at a dead end... anyone got a suggestion on what i could check out?
it turns over fine its getting fuel just no go.
3.8 with carb and duraspark II or 5.0 with CFI and EECIII?
5.0 cfi
you didnt answer the question.  just cause its cfi does not tell us anything about the distributor type.
83 was one of those years where the ignition system could be ds1 or 2.  Also, your CFI type would also be a little different from the 84 and up.
i believe it has the earliest form of eecIII
It is an EEC3.
IIRC they have a separate ignition box, similar to the old DS set-up.
EEC III uses the duraspark III ignition system.
It has a CPS (crankshaft position sensor) instead of a stator in the distributor.
The CPS is mounted somewhere near the crankshaft pulley.
Check that the wires to it are not broken. If the wires are good try replacing the CPS.
The ICM for DS II and DS III look alike but are different. If you are not sure you got the right one, put the original back in.
Still no spark?
It did that to me a couple times.  I would jiggle the connection for the crank sensor (happens to be beside the dist) and it would fire right up and be good for a couple more months.
really?, hrm... i need to do that when i get money for another battery :D cougar had bird battery, bird has battery back... ive been too busy to tinker with it... plus im more focused on the birdy at the moment... ask my pos dodge truck lol.
Does my car run yet?
Quote from: 87thunderbirdBlackJack;216868
I'll be in Ft wayne the 17-20th at Comcast Taylor st.
yes, and i know two things that need fixed on it.... 1 the crank position sensor.... and two i need to ditch the cats and open that exhaust up a bit.
other than that she is gonna make CJ this year.
Ill keep my eyes open Scott.
