Topic: Smog pump (Read 2521 times) previous topic - next topic
Smog pump
How does the smog pump mount on the engine? I have tekne mine off and forgot. I have the top bolt in the bottom of the alternator bracket but thats is as far as i have gotten. thanks
Re: Smog pump
Just leave it off, and plug lines to it. You dont need it, I done that on all my thunderbirds. Just need to get a smaller belt.  The parts store can fix ya up.
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
Re: Smog pump
it mounts directly to the bottom of the trash can. along with all the hoses and  attached. all my cars have it removed to, and it did nothing for emmissions.
Re: Smog pump
Unless you have emissions testing, then you may want to keep it.  If not, here's some help to junk the pump and tie up all the loose ends:
http://www.foxtbirdcougarforums.com/showthread.php?t=1022&
1987 Thunderbird 3.8. Sold :(
Re: Smog pump
There is a small straight steel bracket about 4-5 in long that bolts to the bottom of the air pump and then goes the the timing cover lower stud
Re: Smog pump
Just FYI... the Cardone replacement smog pumps changed the lower mounting point to SAE thread from Metric. The bolt that comes in the kit isn't long enough. You must buy a new one.
