Topic: 245/50/16 tires (Read 3249 times) previous topic - next topic
245/50/16 tires
Just a little background, I currently have 225/60/16 tires on my car, which has the "snowflake" wheels.  The car originally came with the 14" wheels, but I upgraded to the snowflakes a long time ago. I really want to put 245/50/16 tires all the way around, but I'm concerned they will rub my front struts.  Has anyone 245s up front on the snowflakes? Any help is appreciated!
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
245/50/16 tires
I don't have them on snowflakes, but I do have them on some 16x7" mustang wheels. I've never had an issue. Plenty of clearance.
245/50/16 tires
Tbird232ci....do you have the 10in or 11in brakes up front?  I still have the 10in brakes
1988 Thunderbird
245/50/16 tires
I always ran 245/50/16 on my TC with stock snowflakes. They fit great. Every once in a while, on an absolute hard turb in a parting lot a front one would scuff the inner liner, but no real issue.
Front
Rear
And even with 245/50/16 Nitto Drag radials.
245/50/16 tires
Cool pics...that size tire looks good on the car!
Mine still has the 10in brakes (it wasn't a TurboCoupe). I wonder if the front spindle spacing is the same between the regular 88 birds and the 88 TurboCoupes??
1988 Thunderbird
245/50/16 tires
245 on mine snowflake out back and plan on going bigger to 255X50R16
245/50/16 tires
I have the 11" brakes.
I have both a TC and non-TC, and the spindle spacing is the same, or at least so close it's not noticeable. I had the turbines from the my red bird on my TC, and they fit exactly the same.
Also, I never had any rubbing issues with my 245's. Might be between different tire makes. I use Falkens.
These are the only two pics I have hosted of the car before it got stripped.
245/50/16 tires
I can't make a full lock turn w/mine.  It's the same w/snowflakes and the aftemarket rims.  The car is lowered w/11" brakes.
245/50/16 tires
They typically fit fine, I ran them, but I won't do it again because being more concerned with handling, I now know that a 245 is a bit wide for a 7" wide wheel and gives more sidewall flex.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
245/50/16 tires
Tbird232ci,
Did you modify the front end of that grey bird?
88BlueBird,
You shouldn't have to worry about 245s, and the rear wheel wells can handle a little more, too.
__________________
Twin '85 TCs
White/ Grey 2-tone
245/50/16 tires
No sir. Mustang wheels have a bit more backspacing than the snowflakes, so the stance appears to be wider. The rear uses Lincoln axles, in addition to the offset to fill the wheel well a bit better.
I have the exact same setup on my black bird in the user rides section.
245/50/16 tires
okay, thanks.
__________________
Twin '85 TCs
White/ Grey 2-tone
245/50/16 tires
Thanks everyone for your feedback.
I need to get some new tires soon.....mine are going on 10yrs old!
1988 Thunderbird
245/50/16 tires
What did you go with??  i have 245/50/16 on 16x8 wheels and they
fill it up nice with a real wide look just shy of sticking out the wells.
on a 1988 Cougar btw.
\m/__\m/
245/50/16 tires
I just ordered the 245/50/16 tires. I will let everyone know how they fit...
1988 Thunderbird
