Topic: Got a free mark 7 engine for my bird (Read 3447 times) previous topic - next topic
After I blew up my standard 5.0, somebody I know has alot of fox bodies he sent to the yard, and he gave me a 1990 mark 7 for parts on my tbird. What kind of axle ratio is on the 90 marks? would the air bags fit the bird? Thing only has 60k miles on it. I think this is the best score I ever found lol. The thing run for a sure. He moved it around the lot a few times. will have pics maybe this weekend when I pull the engine. :burnout:
Children of Bodom!!!
Lucky SOB.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Don't waste your time on any of the air suspension parts...they're all junk...that's why you see so many Mark VII's with the nose or tail(or both in some cases) in the weeds...most Mark owners replace the air suspension with regular coils, shocks, and struts.
You can use the front spindles rotors and calipers for an easy 5-lug conversion in the front...or you can buy 4-lug mustang 5.0 rotors and still use the mark calipers.
Good luck,
Don
Um actually the whole rear end is a great swap in a Tbird.  I have done it twice myself now.  I used rears from LSC Mk7 on two my Turbo Coupes.  You usually get a 3.27 Limited slip rear ration, and a bit wider track width to help fill out those rear fenders.  I will be doing it a third time to an '85 Bird, but this time with a different ratio for a different engine/trans combo.
But the part about the airbags is correct, dont bother with them.
Actually the issue WAS cost...
Most people are scared of the design and Ford along with most repair shops used to charge an arm and a leg to swap the bags out.  The bags can be had for a relatively inexpensive price today compared to what they once sold for and if you have some mechnical skill they're not much harder to work on than a normal suspension setup.
My car is still on air.
Matt
Another question. Is the axle an 8.8 or a 7.5?
I got a 7.5 from one. Others said there are 8.8's too...
'86-up LSC have 8.8...
Quote from: Sick88Tbird;214479
Don
the spindles will only fit if you use the linc ball joint also, it's a larger diameter than the other fox ball joints(but same as an svo mustang). the rotors will work on any 87-88 tc or 87-93 mustang 5.0 spindle.
86 thunderbird elan
86 mustang coupe
If the year of your T-bird is 86' and ealier, then you have to use 87' and up LCAs or 94' and up Stang LCAs. When I installed my lincoln spindles and rotors, I changed out the LCAs with tubular units for a 94+ stang. That's a killer score though :)
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Quote from: fordguy;215557
:bowdown:  I wished I had known about that before I bought those stang LCAs
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
axle is 8.8 3.27 gears
air ride is NOT junk, but not worth it to add to your bird(its actually easy to fix, and diagnostic if you take the time to do so.)
Well never mind. My dad screwed me out of 4 different 5.0`s, standard and ho`s. My tbird is up for sale for a grand. needs an engine. Theres not much fun in it anymore.
Don't give up on it.5.0's are cheap and easy to find.All you need is an SO 5.0 (Non-H.O.),and grab a few cheap parts,and there you have it,an H.O.H.O parts are super easy to get and cheap.H.O cams can be had for $25.00,headers are cheap,intakes are really cheap (The H.O Mustang pieces).Build that car.I've been working on mine for a freakin' year.You need patience,and you have to know that you'll run against a brick wall every once in a while.Coming to a dead end is easy,it's how you deal with it that makes all the difference.In the end,you have to do what is right for you.
