Topic: Removing Seat Covers (Read 1511 times) previous topic - next topic
I couldnt find it in the search so sory if its a re post...
I need to take the fabric covers off a seat of Sport seats. I dont want to tear up the foam, thats my main concern. Any tips or trick to taking it off. How are thet attached? i figured its just pulled and attached to the seat frame but i dont want to find out there is glue also after i started and messed up the foam.
It's a pain in the ass, I too tried to remove the fabric from the frames
(TC seats) and came close to ruining one, so I put it on hold...
Quote from: FordTruckFreeek;213789
Thats no good. was there glue? what all did you find out about haw the fabric is attached?
hog rings and i think the foam is glued to the seat frames too...
I bet the E-man would be able to say for sure...;)
Its not too bad.  You have to un-zip the fabric on the bottom of the seat back, and then get the head rest out (Hardest part)  Once you get that done, its pretty easy to pull the entire cover/foam off with two people.  i did it in my living room the other week :)  I had a badly cracked seat frame, so it was a necessity.  The bottom part, I have never done.  If you need to take the cover off of the foam, that is a little more complicated with all the hog rings that attach the foam to the cover itself.
88 TC, Lots of Mods.
Any advice on removing the head rest?
Got the head reest off before i went to sleep. took about a min. for the driver seat and about 3 for the pass. I just wiggled it side to side and they popped out. I'm going to pull tops off tonight.
I think ill see how the dye works on the head rest first. then try the covers.
Ok so i got both the backs off and half of one of the bottoms. The hog hooks are a bunch of bull.
I got it to the point that the pull out leg rest thing is in the way. how do i pull that off?
