Topic: full digital (Star Wars) cluster upgrade (Read 1859 times) previous topic - next topic
I've been researching the wiring for the full digital conversion, from the base digital cluster.
Before I jump into doing it, I was wondering if anyone has done it with complete success.
2. are the sensors still available aftermarket?
3. would it be more worth upgrading to full buttstuffog then digital?
I believe the sensors are still available aftermarket (I think the fuel sender may even still be available from Ford). As for whether it's worth it, that's a matter of taste. Some people like the disco dash (I do), some don't. I think it's a great retro 80's component in a retro 80's car.
To put it another way - if I were American I wouldn't even consider the buttstuffogue cluster because of the 80 MPH speedo and the price/rarity of a 140MPH unit. We Canadians get a 200 km/hr (120MPH) unit, though, so that's what I went with :hick:
I'm going to do some poking around with the wiring and see if all the connectors are at least in my car. I don't know if it was offered in a 3.8 car. and I don't know if they used diff. wiring in specific cars.
I like the full digital look myself, and a speedometer that only goes to 80 or so doesn't  really matter much to me.
It's easy enough to mod the digidash to 199MPH anyway :D
The connectors won't be in your car - well, they will (they should be the same as the base cluster connectors) but they won't be pinned the same. You MUST re-pin the connectors for the different dash, or you'll destroy the dash and Lord knows how many sensors the moment you turn the key on.
Quote from: Thunder Chicken;213308
Thanks, good to know going in.
i posted pics of the cluster pin outs on the thread you mentioned.  I figured you read that already.  stare and compare ect.
I did the base cluster to full digital cluster conversion on my car. It's not all that difficult, just time consuming.  I had to repin the connectors at the dash and even lengthen most of the wires, because they wouldn't reach the other connector. It was a PITA...but it works now and looks awesome at night. I had the fuel tank and engine out of the car, so replacing the senders was no big deal.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Quote from: 88BlueBird;213397
Did you use sensors from another car or buy them new?
I bought the coolant temp and oil pressure sender new from Napa. The fuel sender I purchased on this forum.
1988 Thunderbird
Quote from: 88BlueBird;213445
Thanks
