Topic: maf sensor (Read 1438 times) previous topic - next topic
maf sensor
i think the maf sensor on my 95 4.6 cougar may be out. will the one off my 93 3.8 work on it? i pulled it put from the intake tube to which it's mounted and both filaments are fine.
It's always fun until someone loses an eye. then it's fun ya can't see.
-James Hetfield back when metallica was still making good music.
maf sensor
Do you have a code that is pointing you to MAF?
maf sensor
Check the other thread you asked this question in.....
maf sensor
No one here really knows for sure... You'll probably get replies they're all the same, but I know different... Try it and see, IF it runs OK and doesn't throw a code then it's prob OK...
As I mentioned in the other thread, a 5.0 Stang meter will not work properly on a '95 4.6... It did at least run on that meter(till the weather got cold)... When the original failed, it would barely idle... In contrast, a MAF from a '96 4.9L E-250 Van works fine(with a connector change) on the '93 4.6 Grand Marquis... Guessing it possibly would have been OK on the Bird, but mounting is different and I didn't want to hack it up...
