Topic: exhaust hitting the driveshaft. (Read 1396 times) previous topic - next topic
its a set of 2 chambers flomasters on flowtubes do i have the fowtubes turned the wrong way? tried to move the lers away from the driveshaft but they went back to being really close to hitting.its the car in my signature.
Get a set of BBk shorties.If you got all the hangers right,
your stuff won't hit.Thats the part thats hard.
X2.I use the BBKs,and the are really THAT good.
I have Flowtech flow tubes as well as Flowtech Afterburner lers and they don't hit. Are you using lers with an offset inlet and outlet?
BBK's suck.  I have BBK ceramic coated shorties (awesome headers) but the h-pipe hangs WAY low.  I can't go over any speed bumps with any people other than myself in the car without MASSIVELY sing.  It's the worst sound ever.  I think the whole shiznit's gonna tear off next time, no joke.  granted I have coil-overs and a wicked lowered stance but still, even visually it looks like .  I can stand on a level surface looking at the car from about 15 ft away and see all the pipes hanging down.  garbage.  just my 2 cents and also, i'm venting after all the problems I've had with my family (extra weight) in town and using my car to be tourists!  LOL
1988 Thunderbird Turbo Coupe
the lers are offset  inlet/outlet .well theres enough room to put one finger inbetween the driveshaft and the ler on the passenger side witch is the one im worried about hitting .also does anyone have a problem breaking the ears the bolts go threw on the starter?becuase i just pulled one with both ears broke off the starter was just sitting there.
found the problem one of the flow tubes was turned wrong its not hitting the driveshaft anymore.
