Topic: My 302 build for the Challenge Race Car - cam question? (Read 6789 times) previous topic - next topic
OK, a little background. That 84 Turbo Coupe I made John drag home last year finally has a purpose in life. We're turning it into a race car for the Grassroots Motorsports $2009 Challenge. For those of you not familiar with the Challenge, you have to build the entire car for $2009 or less (and be able to prove it), and it has to compete in a 1/4 mile drag race, a timed auto-cross course, and a judged concourse. Obviously a heavy-butt TBird with a 302 isn't the "hot" setup, but it's what we have, what we're familiar with, and our goal is simply to finish and still have a running car. That being said, we do still want to give it our "best shot" and maybe even eek out at least a Top-10 in the drag race.
OK, so the motor is a roughly 84 vintage 302 CFI with a hydraulic flat-tappet cam that's all of 150HP (maybe...). Obviously a rebuild is in the cards!
So I was at the Portland swap meet today and I picked up a new "regrind" cam for the 302 (for $35!) from a fairly well-known shop. Specs are as follows:
INTAKE:
.439" lift
207* @ .050
258* advertised
EXHAUST
.454" lift
215* @ .050
265* advertised
115* LSA, 36* overlap
And it's a 351 firing order.
So, is this going to meet our needs? The plan is to acquire a set of GT40 (non-P) heads, an RPM Air-Gap intake, and higher-compression pistons for the build. Nitrous is the current plan for a power adder, but we are kicking around the idea of turbo/blower...
Would be a good cam to pull a boat with..
Im doing a similar setup in my 351 and im going to use this cam
http://www.jegs.com/i/Lunati/638/61003LK/10002/-1
1.7 rockers intake 1.6 exhaust.  I know it sounds bass ackwards, but I've been doing some research and it seems High lift, short duration intake/lower lift, longer duration exhaust is the way to go with GT-40 heads.
36* overlap
At what height?  0?  .050?
Here's the cam card:
Advertised Lift: INT .439 / EX .454
Advertised Duration: INT 258* / EX 265*
Lobe Separation: 115*
Overlap: 36*
Exhaust Opens: 43* BBDC
Exhaust Duration: 215*
Intake Opens: -11* BTDC
Overlap: 19*
Exhaust Closes: -8* ATDC
Intake Duration: 207*
Intake Closes: 38* ABDC
So I assume it's 19* Overlap at .050 and 36* Advertised.
It's too small isn't it? Maybe with ported HO heads it will work, but 300HP might be a stretch for it...
If your buying pistons, match a cam with them.
That way you get the most bang for the buck.
Are you putting $2009 in motor or everything?
$2009 for EVERYTHING, car included. That's why the budget is so short! :hick:
Quote from: P71;212997
:mullet:
Mullet budget! I love it :hick:
Quote from: P71;213554
Mullet Budget = Stolen parts + $5 for PBR?
This is the race I would shoot for with a T-Bird: http://www.24hoursoflemons.com/  Would do pretty well stock.  $500 budget (+safety costs including mandatory cage)
Safety costs are not included in that $500 Bux.  A cam would be though.  It's also a $500 registration fee PLUS $100 per driver.  This race IS NOW a true 24 hour event.  To do it I would say 6 drivers (4 hours each) so that's $1100 plus a car ($500) plus tires, a rollcage, a harness style seatbelt and GOOD brakes.  Truthfully I'd budget at least $4K for that one.  It would be a BLAST though.
Quote from: V8Demon;213853
hence the "+safety costs" :)
Probably.
Jalopnik is running a 302 powered Volvo 244.  Someone is even entering a Buick V6 powered Triumph TR7.  There is quite an eclectic band of cars at these events (ex: Porcubimmer - the BMW with the pen 15s on the outside for a change :) ) and the themes are quite amusing. Not too mention the fun stuff like the Personal-Injury-Lawyer Anti-Slalom, the Marxist-Valet Parking Challenge, and the Wide Open Throttle Rodthrowapalooza. Plus the prize money is paid in nickles! Lots of fun stuff. When I found out about it, I was hooked and have been reading as much as I can from teams getting their cars ready. I even dreamed of entering lured by the $500 budget...but as you say, costs rise pretty quickly and I'm quite far from any of the race sites.
Anyway, sorry about the thread hijack, I just think the 24 Hours of LeMons is really cool.
