Topic: More door panels (Read 2044 times) previous topic - next topic
More door panels
Here's an attempt to simplify the door skin.  The arm rest and map pocket are permanently attached to the panel.  LEDs are in the door light and in the two armrest screw holes facing downward.  This configuration uses five fewer screws to mount the panel to the door, including two for the speaker panel.
A local interior supply had some special velcro tabs ($1 ea), we'll see how those work in place of the factory style push pins, and for mounting the speaker grill.
Sorry about the py camera work, the autofocus is on the fritz.
__________________
Twin '85 TCs
White/ Grey 2-tone
More door panels
They look pretty good. Any chance of getting pics of the LEDs at night? I'm curious what those would look like.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
More door panels
I'll take some "in action" pics once the panel's mounted.
__________________
Twin '85 TCs
White/ Grey 2-tone
More door panels
Nice work so far.I'm curious to see how the  Velcro tabs hold up.
More door panels
I'm curious about the tabs also.  To be safe, I'm going to epoxy a strip of metal to the board as a mounting point for the velcro to disperse the force.
__________________
Twin '85 TCs
White/ Grey 2-tone
More door panels
How did you attach the arm rest to the door panel? Genius idea.
More door panels
I went through a few ideas.  This latest uses plumbers tape.  I'm going to road-test it for a while before converting the other door panels I have, just in case.  If this works, I'll post a more thorough write-up when I do the other panels.
__________________
Twin '85 TCs
White/ Grey 2-tone
More door panels
Please do, I absolutely LOVE the door panels on the TC's, but HATE how flimsy they are.
More door panels
About the only thing I'd worry about is the arm rest coming off too easily. All it takes is a little push to snap that sucker right off. I think that's probably why Ford designed multiple screws to go through the armrest and into the metal of the door in the first place. ;)
Otherwise I like the idea...nice job so far. Looking forward to the real-world testing phase.
More door panels
Eric,
Four of the factory mounting points are used, all "topside".  The three not used are the the two underside points and the one behind the reflector.  My main concern relates to the durability of the fiberboard that secures the screws and tape.
At this point, velcro or screws could be used to secure the forward lower corner, depending on the condition of the map pockets.
__________________
Twin '85 TCs
White/ Grey 2-tone
Okay, back from the dead.
The interior is starting to go back together .. I hope permanently.  NOT!  Just after completing both doors, I remembered the new outside door handles which aren't ready yet, so the whole thing will have to come apart.  The panels will be easy, the new RAAM insulation, not so much.  That stuff is permanent!
First pic is the patch for the access hole.  The odd-colored wiring is what I strung the other day for the door locks.
Second pic is the heavy insulation.
Third pic is the foam insulation.
__________________
Twin '85 TCs
White/ Grey 2-tone
More door panels
As requested, the added lights.  Sorry about the quality.  Getting something that relates the correct impression is difficult.
I'd probably change the angle a little next time, so that they're pointing almost straight down.
Note the door new inside handle(s).  And, somehow, I've managed to misplace the armrests.  They'll show up eventually .. I hope.
__________________
Twin '85 TCs
White/ Grey 2-tone
More door panels
Oh yeah for me it is going to be a real challenge to satisfactorily reattach my armrests to the door panels on my 84 model. Then there is the issue of the py power door lock switches that install behind the inside door handles. I don't see too many of these cars anymore with the armrests intact since they break so easy.
