Topic: Cooling Problem (Read 1325 times) previous topic - next topic
Cooling Problem
My daughter's 86 3.8 tbird is acting strange.
Now that it's running clean and smooth and the thermostat is new the car heats up to almost the red area and then in cools down immediately to mid-range and then repeats.
Almost like the thermostat is cycling open and closed.  It's very strange.  Or, could it be the gage?  I've never seen a car do that.:mad:
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
Cooling Problem
Pull the codes?
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Cooling Problem
Radiator full?
Cooling Problem
Could be a bad thermstat, or early signs of water pump going out.
Cooling Problem
how old are your hoses?
did you properly relieve air out of the system when you changed the thermostat?
i have to ask, was the thermostat a pos junk "stant" one? :flame:
Cooling Problem
fan clutch
water pump
too high of a temp t-stat (or defective t-stat)
remove the t-stat and drive to see if problem is still there.
Cooling Problem
I was thinking all those things.:D I'll have some troubleshooting to do.  I didn't do the tstat myself.  It was changed as part of the emissions repair so I don't know what brand it is.
Thanks all.  I'm leaning towards the tstat and/or the fan clutch.
