Topic: E303 with GT40P Heads (Read 8652 times) previous topic - next topic
Now that I have two birds,I want to beef up the 5.0. I have a HO EEC-IV,a E303 Cam,and a GT-40 EXplorer intake. Just wondering if the GT40P'S will cause piston to valve clearance problems. I dont have heads yet but can get GT40P'S or E7'S. I know the 40p's are better just want to make sure they will be OK before I buy a set.
I’m assuming you have an E6 bock w/ flattops
Almost all get lucky w/the E7s I don’t think I heard of anyone having a problem, though some will tell you to still do a piston to valve check. Pretty sure the regular gt40 will have similar results but be more careful bigger valve and I think I herd of one or two lucky people out there. Now as for the gt40p head it has a smaller chamber and I never herd of anyone put them on an E6 motor.
SCRATCH SCRATCH SCRATCH SCRATCH SCRATCH SCRATCH SCRATCH
 I just reread your post your going w/the E303 cam now you just tighten the odds even more.
I know. I  see that there are several people running e303's with e7 heads and a e6 block,so I guess I will go that way.
You'll need mass air with that E303...
X2.I know first hand about that.
I have the pigtail and meter from a 92 5.0 GT. What else do I need to go Mass Air? I found a article on hooking up the meter to the EEC-IV, is that what you did?
You need the Mass Air EEC... Most of the time they'll be ID as A9L or A9P...
Another computer to search for is an A3M or A3M1.  It was a service replacement for the A9L & A9P.  They are not as commonly known, so prices are often considerably less (perceived as less desireable).
I run the A3M
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
I would say throw the E-303 cam in the trash...or E-bay it to a mustang guy...*IN MY OPINION*, the entire alphabet cam line is junk...Lunati makes a few real nice cams with more exhaust duration...I drove an E-303 equipped 'Stang with headers/T-5 and 3.73's...it had mass-air and still refused to idle when cold...I couldn't even come close to imagining driving with an AOD behind it...definitely suffered on low-end torque...the car was stripped down to around 2700lbs and ran 12.70's on DR's...but wasn't very fun on the street.
Um,well,I have an AOD and the E303,and the car has some wicked mid-range power,and idles a little "loapy",but is great.I have 3.55 gears.When I floor it from a stop,the tires don't have a chance (255 40 17).
My experiene with the E303, fuel injection and a manual trans, was not positive.  It surged and stalled quite often.  It would also buck at a low (engine) speed in any gear.  When it did idle it sounded pretty tough, but what a PITA.
When I swapped the long block to another car, it was carburated with an automatic (with a stall converter). Then it was pretty easy to live with.
The fuel injection set up may have run better with a custom chip tuned on a dyno.  I had a mail order one (specifically listing surging and stalling as the main runablity problem).  It helped, but it was still miserable to drive.
Most of my reading on the computer is not positive for the E cam.
I think I read this on corral which made me laugh they stated there’s only 1 E-cam out there and we keep passing it along to the next guy.
Yea alot of people told me to sell the E303. I decided to go with a stock HO cam instead. That way I dont have to find another computer, plus it isn't going to be my race car, I have the 87 for that.
I hope you're not using the stock T-bird short block. If you are those pistons are going to bend the valves on the GT40P heads.
