Topic: 2.3 turbo (Read 2919 times) previous topic - next topic
2.3 turbo
just bought this car.had a cracked head. replaced the head,he installed a ranger roller cam.now it wont run.it starts runs about 5sec then dies.i think its fuel related.what do you think.i get car home friday.any help will be helpfull
2.3 turbo
Did it run before it was taken apart?
What makes you think it's a fuel issue?  Checked fuel pressure?
Could be timing out of whack, could be a vac leak.
Need more info, which you most likely won't have until the car is in front of you.
2.3 turbo
yes it ran before head was replaced.yes you are right i wont know intell its in front of me.it could be timeing out.head was cracked in cylinder # 2 also he installed a ranger roller cam witch i dont know if fireing order is same.
2.3 turbo
The cam has nothing to do with it as long as it was set (timed) properly.
2.3 turbo
starts runs for 5 sec then dies sounds like a TFI  ignition module.
2.3 turbo
is the hose that goes between the vaf and turbo inlet on correctly and the clamps tight? just a guess
louie  :birdsmily:
My famous last words:
2.3 turbo
ok have car home,timeing was 180 out fuel pressure key on engine off 40 psi start it it drops to 30psi have not replaced filter yet. has after market boost controll valve,vaf lost.
2.3 turbo
Quote from: kclerman;211483
Pressure is SUPPOSED to fall to approx 30psi running... Your F/P regulator is working...
Under boost it should be 39-40 psi + one pound for each PSI boost... OR approx 55psi at 15lb boost....
2.3 turbo
can spray brake clean down throttle body and stays running
2.3 turbo
What do you mean by "vaf lost"?
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
2.3 turbo
ok up date got car to run but have to hold vaf door open!also noticed vav line to egr was melted shut. and also vac line on tree marked g was melted.
2.3 turbo
Then your problem is vacuum leaks.  Also you need to work on your typing/proofreading, your posts are hard to understand.
84 SVO
88 TC
87 XR4Ti
2.3 turbo
ok,sorry brain works faster than my typing skills.
2.3 turbo
im still thinking its fuel pump,did compression check 160psi per cylinder cold,have ignition,timeing is correct.fixed vacuume leaks.
2.3 turbo
i got it!!!!!!!:shakeass: the guy i got it from turned the vaf backwards dah! i never noticed it untill i went to bolt air box back down and bracket  would not line up with holes.:burnout:
