Topic: Turbo problem (Read 1927 times) previous topic - next topic
Turbo problem
help help help... I have a  1984 Turbo Cougar that has about 70,000 original miles. A few months ago it blew a head gasket,so I put it the garage and fixed it over the winter, all of the motor is back together now. Problem is the fuel pump in the tank will not work nor will the gas gauge work, no blown fuses, pump is good (I dropped the tank and ran power straight to it), no broken wires that i can see,inertia switch is good, I even jumped it out. i am not getting any power to the inertia switch. any ideas    thanks
Mike
Re: Turbo problem
Look for the EEC power relay (under the dash on the pass side just above where the ECU is in the pass kick panel) or the fuel pump relay (in the trunk attached to teh back of the seat).  One of them might be stuck.
Do you hear the inline pump prime when you turn the key to the "RUN" position?
Re: Turbo problem
thanks for the reply, no you dont hear anything when the key is turned on.
Mike
Re: Turbo problem
Check your relays.  You have 2 pumps in that car ...you should hear them prime.
Glad to see another 84 XR-7 owner:banana:
