Topic: Rear lift springs (Read 1522 times) previous topic - next topic
Rear lift springs
Anyone know where to get lift springs for rear of car? I just want 1"-2" Thanks:burnout:
Rear lift springs
Maybe some cargo coils with ajustsble lowers would give the lift you want?Your the first I heard who wanted to raise the car.
Here's a link for moog springs, gives all the specs ,maybe you can come up with something that would work.for referece the stock replacement # for an 87 is 8599.
http://bbb-carb.com/moog_Coil_Springs.htm
Rear lift springs
Just install a set of CHE adjustable lower control arms with your stock springs. It'll bring the car's arse up at least an inch at the LOWEST setting and can be jacked up even more via the adjusters...
Rear lift springs
You could always instal air bags in each side, then you could raise and lower as you want for about $60. I have had mine set up this way for about 4 years. It works great for when I ride 4 up in the car.
85 TurboCoupe. 306/DartSr's/Vic 5.0 Intake/B-25 Cam/Vortech YS trim/A9L Computer and Mustang Harness/ Pro M 77 MAF-50lb inj/TKO/15X10 Prostars/MMR Coilovers-90/10's-50/50's Chucks shock brackets/CHE Adjustable uppers/lowers. FR manual rack/steering shaft.
92 LX Coupe 306/Gen VII DFI/ No engine /TTI Race kit T-76/Comp cam/ 15X10 Prostars
Rear lift springs
Thanks guys, I have a tire rub issue whenever my kids are in the back,Plus I dont like the front looking higher than the back.:burnout:
