Topic: best valve cover gaskets? (Read 1659 times) previous topic - next topic
whats the best valve cover gasket for no leakage on steel
5.0 motor covers ? ford --felpro or others?
I use the fel pro, re-usable rubber ones with the washers in the bolt holes... I have never had one leak yet.
Quote from: 1WLD BRD;209247
"Perma-Dry" or Cork?
I need to pick up a set of gaskets myself... Not sure if i should fork out the extra $15+ for the "perma-dry" or not, heh.
I put cork on everything I can..
Ford.
Quote from: SLEEPER T-BIRD 87;209293
you've also been through more motors than anybody i know, too.
cork gaskets suck. best ones are the metal with the rubber lining.
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;209301
By choice
I'm only coming up with these 2 choices (locally at least, And for a 6 Banger).
http://www.autozone.com/N,15300524/shopping/partTypeResultSet.htm
I'll probably just go for the Steel Stamped Perma-Dry Plus...
The ones that are on right now are Cork, And are really stiff, cracked and drenched in oil...
X2, I never use cork, Even if I am just going to flip the car, I will redo the gaskets with rubber, whenever I take something apart..
