Topic: Help, please (Read 771 times) previous topic - next topic
Help, please
My roomate has a 98 mustang. i need to figure out how to remove the door panel on the passenger side to pop out the door where it was creased. other than 2 screwes behind the cup where the door handle is. It looks like it should just pop off of the door, but it won't budge. i wasn't wanting to force it if i was missing something. Anyone have any experience with this? i can't find anything on the web.
[SIGPIC][/SIGPIC]:cougarsmily:
Help, please
Pop the plastic trim off thats behind the inside handle. You have the pull the door panel up to remove it-if you force it out(towards you) you will break all the clips. Depending on if you have the mach 460 sound system-you may also have to remove the triangle shaped piece of plastic that covers the screws for the outside mirror.
Help, please
ok, that makes sense. his is pretty basic, it doesn't even have power windows. i think it's the basic sound system.  thanks for the tip!
