Topic: Picture needed of stock cluster at Night (Read 1952 times) previous topic - next topic
I was hoping that someone could post up a picture of the stock cluster at night.  From what I've seen, the needles aren't that bright, are they?  Has anyone found a good way to make them brighter?
What kinda cluster?
:pics-stfu:
 Project Thread with pics
mabe you have a burnt out bulb or bulbs
Quote from: blu84302;208676
What kinda cluster?
Any of the full buttstuffog clusters.
http://www.foxtbirdcougarforums.com/showthread.php?t=13543&page=5
LED bulbs can help a bit...
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
also something that helps is giving the inside of the the cluster a good coat of reflective paint. my 84 cluster the inside that the lights were supposed to reflect off was dull white.  i gave it a coat of that chrome paint and it was much brighter with the factory bulbs. also i could get you some pics of my cluster at night with the lights on for you if you would like. it is an buttstuffog cluster.
it is this cluster though. probly not what you want unless you have an 83-84
Gently sing off the white paint from the underside of the needles (speedo and tach), then spraying them with flourescent orange model paint, seems to help quite a bit as far as visibility. Several people mentioned that before, and I've also done it myself...it's a nice mod. The other needles are a lot tougher since the bi-metal composure of the gauge means that you can ruin them easily.
I don't know if these photos will help you or not. But in real life the effect is pretty close anyhow:
Wow whats up with that first cluster. Pre-production concept or something?
1986 XR7 production cluster with boost gauge.
EDIT: Actually you may be right...the tach lists "10, 20, 30" etc. instead of "1, 2, 3" etc. Ford is notorious for using pre-production or prototype parts in their brochures, which is where I got that photo. Also, we know that the top photo is not correct because it appears that the ammeter is actually working. ;)
Sorry about that, my bad.
Yeah, and the speedo has ticks up to 100, as well as just looking slightly different all around.
