Poll
Which Do you prefer?
Total Members Voted: 15
Topic: Subframe connectors (Read 1951 times) previous topic - next topic
Subframe connectors
Thinking of doing subframe connectors in my car. It will be used for street/strip. Which to you guys prefer and which will be the strongest?
2 88 TC's (1 is the 2.3t race car, other v8 maybe?)
06 dodge dakota 4.7 v8
79 chevy k-10, built 350/turbo 350
Diverse ain't I?
AMSOIL Dealer
Subframe connectors
I'll eventually have some welded in.I'm going under the floor in mine.I just can't bring myself to cut up my floors.i figure that even under the floor,it'll be way better than stock.
Subframe connectors
Talk to Chuck!!
Subframe connectors
thru-floor FTW!!!one!!1!! :hick:
Subframe connectors
Quote from: gumby;207496
WOW!
Subframe connectors
If you have the oppurtunity and the patience through the floor is the way to go.
Subframe connectors
THur the floor is much stronger,but more intense to install.
  Really depends on the planned use of the car? How much HP and such.
 When my car had a blower and a T5 the under floor sub frames were
fine.  Just not up to the task with the turbo combo.
Subframe connectors
The '83 has under the floor.  However they were installed 9-10 years ago and the car also now has a cage.
The '80 will be getting through the floor SFCs.
Subframe connectors
I have both Thru-Floor SFCs and Lower SFCs, but I'm setting mine up to play on a twisty track and will be driven on the street.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Subframe connectors
Unless you are going for a low rider I would do welded under the frame.  You can do your own with some tubes the width of the frame and flat plates.  My T-bird is much more solid after this mod.
TED
Subframe connectors
I did mine under the floor, but then again I didnt build a 800 HP monster. and they were fairly easy to weld in.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
