Topic: The final straw on the Sport... (Read 2958 times) previous topic - next topic
Check this gem out. Some ass of a shop cut the firewall out to change the heater core, and it looks like they copper-brazed the chunk back in. This poor, poor car. If I had paid a shop to do the heater core, and THIS is what came back, I'd own the  shop after a lawsuit. This is ridiculous! I was showing it to a neighbor who used to work for the DOL out here in Washington, he said the car would have failed inspection and had the title branded as non-street legal. I can't believe somebody got away with this...
Oh well, it's given up it's organs to keep other TBird's on the road and has now been recycled. Can't save them all :(
didnt even try to hide it did they
Mike,that pic shows the line with the dryer.You have that and the others I need,still,right?i haven't heard from you,did you get my payment and note?
By the way,Ford should've designed a panel there just for removing the eater core.The '77 through '79 T-Birds and Cougars had a panel under the hood,remove a few self tapping screws,remove the little panel,and pull out the heater core.You can change one in about 5 minutes....literally.If one had a spare car to get the metal from,perhaps fabbing a hole and panel for that purpose for our cars could work.I don't see how that could fail you in an inspection,though.
That looks like lazy previous owner work.
I agree.I don'th think a shop,even some py ones,would do THAT kind of blatant junk.
Check out some Econoline vans and you'll see a good portion of them have had their heater cores changed the same way.
Quote from: vinnietbird;207319
It was my plan to go this route myself, if and when my heater core ever went again. I had to pay a shop for 8hrs labour when I had it changed the first time. So yeah, a removable panel is a great idea. A hack job and some glorified soldering is a poor idea.
It's really not that hard to do the right way by pulling the dash out far enough to get to it. It's just time consuming and tedious. PITA: yes; HARD: no... Hell, I'd rather change a heater core than swap a lower intake manifold or change a clutch.
Cutting out a section of firewall to get to the heater core is akin to breaking off the wheel studs to change a tire:hick:
If you say so. Removing the dash to replace a heater core is akin to removing my nose to shave my face.
Quote from: Dogcharmer;207437
I agree...The first time I changed out a heater core in a fox bird it had to be the most frustrating car related work I have ever done. I cussed the design engineers every which way.
Now I know where the "hidden" bolts are and can get one pulled out just enough to get the access panel off the top and pull the core out.
Still a pain in the a@* to get to tho.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
I did the heater core the correct way the first time in under 3 hours, start-to-finish. It's not that hard guys. Try stuff like changing the rear plugs on V6 SHO or changing an AMC cam in-car.
I can change an intake in short order.That's a 30 minute job,wicked easy.I did the heater core the first time in about 8 hours.The second time,about 6 hours,last time,which was the first for the Sport,it took about an hour.Eric gave me some VERY good helpful tips which made the last swap a breeze.
You DO NOT have to remove the dash.  You have to move it back, not take it out completely;)
There were some cars when they cut a hole in the wheel well to change spark plugs.
