Topic: hedders (Read 1309 times) previous topic - next topic
hedders
i have a set of headman headders on my 88 302
its the only set i could find whats the best i can get?
hedders
Pretty much any of the shorty headers for a Fox Mustang will fit our cars.I'm using BBK shorties and wouldn't use any other brand.Mine are unequal length with 1 5/8 tubes,going to a Pypes off road X-Pipe.
hedders
Oh,there are probably long tubes as well,but I haven't used those on the Sport,so,I can't say which would work best as for as they go.
hedders
"Best" depends on what you do with your car...
hedders
BBK Shorties "best as far and easy fit just bolt them on" sometimes simple is best.
headers
i have an 83 t-bird with a 351w in it. i run the 5.0 mustang headers  for clearence and easy bolt up. unless your really putting out the hp these will be ok .local junk yard probably has a couple of sets laying around and they should be reasonable. have a couple of pic. on cardomain of them.  use t-bird-mark788 to locate. :birdsmily:
hedders
I will be saving for the rest of my life for these lol
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK%2D6227%2D1HKR&N=700+115&autoview=sku
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
hedders
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
hedders
I had Heddman long tube headers on my 87 Sport. One tube on left side rubbed the crossmember, so we notched it to clear. The ragjoint was close.
I'm using stainless stepped headers on the new motor. 1-3/4" to 1-7/8" to 2" and 3-1/2" merge collectors.
