Topic: Trans crossmember? (Read 1578 times) previous topic - next topic
Trans crossmember?
Anyone have a good crossmember to fit an '86 with a T-5?
Trans crossmember?
id think the cross member would be universal for all fox body cars... be it automatic or manual trans.... i beleive the mount may differ tho.  i could have a cross member available soon tho
Trans crossmember?
Where you at?
Trans crossmember?
Check with cougarman...  I think he still has mine from my TC.
Trans crossmember?
FWIW, the Mustang one is the same if you have to order one.  They run about $65 new.
Trans crossmember?
the mustang one is different than the TC, mustang has a 2 bolt trans mount and TC have a single stud. but the stang one will work if you buy a new trans mount . And i do still have ether's crossmember its in mint condition (looks new) just PM him for a price
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Trans crossmember?
You don't have pics of a TC one handy, do you?
Trans crossmember?
Actually the 2.3 T5 crossmember is the the same as the tbird and mustang.  The auto 2.3 crossmember uses the single bolt crossmember.
Trans crossmember?
well thats no entirely true, the t-5 tc has a unique trans mount and crossmemeber, and the auto uses a completely diffrent style. heres the pics the TC is top and the mustang-tbird-cougar is bottom
Trans crossmember?
Hmm...  Well you could use a mustang crossmember and use a mustang t5 mount.  Probably better that way.
Trans crossmember?
Quote from: cougarman;206979
you are correct:D
Trans crossmember?
Thanks!  Good to know!;)
Trans crossmember?
Quote from: cougarman;207025
you are correct:D
Haha.  I guess I wasn't paying attention.  I should have known if you had posted then the answer was already in there. :D
Trans crossmember?
Look like to me you could drill a hole or two and make it work.
TED
