Topic: Strut bushings (Read 861 times) previous topic - next topic
Strut bushings
I need a pair of the round bushings that go at the top of the struts for 87/88 T-Birds. Mine are beginning to dry-rot, and the mechanic tells me that they should be replaced so the strut will stay in place. He tried the Ford dealer and they don't stock them anymore. If anyone has a good pair or knows where I can get new ones I'd appreciate it.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Strut bushings
The upper strut mounts on the Tbirds/Cougars are not serviceable.  The entire strut mount has to be replaced.
You can buy aftermarket strut mounts from Moog or TRW that are like what was used on the Mustangs that have the cup with the replaceable bushing.
Strut bushings
Okay, it looks like I need the AC-Delco 501-53, now I have to figure out whether ordering quantity 1 gives me just one mount or one for each side...
http://catalog.autopartsgiant.com/RenderScriptTemplate.epc?_cmd=epccat_VehicleWHD&cookieID=2B714D1VE2B714DY1T&yearid=1987%40%401987&makeid=28%40%40FORD%40%40B&modelid=5617%40%40THUNDERBIRD&engineid=5166%40%40V8%2D302ci+5%2E0L+F%2FI+Vin+F%40%405166&mode=PA&subcatid=136@@Shocks%20and%20Struts&catid=9@@Steering/Suspension&clientid=autopartsgiant
edit: I think it means only one mount, so I would have to order two. It also looks like the KYB SM5054 would also work (interesting thought since I have KYB struts, but it probably doesn't matter). I'll try to decide which is best and order a pair. Thanks.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Strut bushings
With those style mounts, you can also replace the rubber bushing with a poly one (for a Mustang).  The pic shown for the Dorman P/N shows how they look.
You will need 2.  The mounts are the same from side to side.
Strut bushings
I ordered the KYB's since my struts are also KYB's. I don't know if anyone makes poly bushings for them, but I've been pretty happy with the stock rubber ones so I'll probably just stick with what they come with (or at least try them out).
By the way, after five months in the shop, the Bird is finally back. Pics this weekend, hopefully.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Strut bushings
All of the aftermarket "cup" type use the same bushing as the Mustangs and you can get the bushings anywhere (Summit, etc).  I may even have a pair stashed in the garage.
Strut bushings
I gotta get a set as well.Mine are original,and on the verge of being wasted.I see a whole frontend rebuild coming up soon.
Strut bushings
I took the car to work today...and boy was I lucky. I took a look at the bushings when I got home and the passenger one was really dry-rotted, much worse than I had thought. The camber is all out and the only thing holding the strut in seems to be the fact that the rest of the bushing is wedged under the hole in the strut tower. So the car isn't going anywhere until the new mounts come in as far as I'm concerned.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
