Topic: quick AOD question (Read 1986 times) previous topic - next topic
quick AOD question
whats the power/torque rating on a stock AOD trans?
88 thandercat if they vary year-to-year and from car ot car.
thanks
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
quick AOD question
V-6,V-8,Been rebuilt in the last 20yr.Tuff ?? to ask + answer.
quick AOD question
this one in perticular has 67,000 grandma's miles behind a v-8. i plan on using a 3000 stall, cooler and shift kit. i was wondering what the stock specs were so i'd have an idea how long it'd last behind the 347.
quick AOD question
You also need the hardened inner input shaft, stock ones break at the 300hp level...
Don't ask me how I know...
quick AOD question
How much do those cost?
quick AOD question
if i get a hardened input shaft, do i loose my lock up capabilities?
quick AOD question
No, you lose the lock up when you go to a one piece input shaft.
quick AOD question
If you go with a high stall non lock up, make certain to use a good external trans cooler for the street.
aod
they aren't to  good for hard treatment in stock form. esepically if you bring up the hp. save your bucks and have one built for your needs ,saves you in the long haul.  :burnout:
quick AOD question
yeah, i know saving up and doing it right the first time is key, and i've been trying to push that idea in every aspect of this project. but i have to draw the line somewhere or i'll be a poor old man by the time this things over with. i figure i can try to make this trans last as long as i can doing the basic stuff(like coolers and shift kets and such) then when it finally does go, either hopefully have enough save up for a stronger aod or t-5.
how hard is it to swap input shafts? i didnt see a write up anywhere on the actual change them out. the only time ive ever touch an auto trans is flushing the fluid in them...so im an auto idiot to say the least.
quick AOD question
I also have a question.  Are the AOD from the 2.3 (non-turbo) Mustang the same as the V-8?  I have one (actually 2) and I was wondering if I should toss it or keep it?
TED
quick AOD question
I guess I found out my own answer through research.
The AOD never came with the 2.3, Turbo or non-Turbo.  The transmission that came with the 2.3 is a A4LD.
Does not sound like it worth anything except for recycle.
Please correct me if I'm wrong.
TED
quick AOD question
If you have a large enough door they make a good stop...
quick AOD question
Quote from: TurboCoupe50;207359
Redneck lawn ornament.:D
quick AOD question
If you can wait,come sometime in May I'm putting a stick in mine.My aod is built for at least 450 on the wheels.non lock up,
2800 stall,got about 6-8 hundred miles on it,Ive got about 2300 in it .let it go for about 12-14 hundred.Got reciepts if interested?
