Topic: Simple question. (Read 1062 times) previous topic - next topic
Simple question.
Can i use a fox stang motor and trans mounts. If not, have any1 found a solution to putting polyurathane mount in a cat or bird? (86 ls 5.0 cougar)
[SIGPIC][/SIGPIC]86 COUGAR LS 5.0 stock. Soon to be project "Cheetara"
85 Ramcharger 318-727 "Big Girl"
Simple question.
Yes,you can use tthe Stang stuff.Your motor mounts are the same as the Stang's.The '87/'88's are different.
Simple question.
No, you can't use the Stang stuff. '86 has the same style mounts as the 87-88, which are different than Mustangs.
So much for it being a simple question :hick:
As for poly mounts, ChuckW makes and sells some very nice 86-88 poly mounts. See his listing in the "Vendor's section"
Simple question.
What Thunder Chicken said...
Simple question.
My mistake.I thought that the earlier motor mounts were identical to the stangs.I feel like a bad person.I'll go ahead and punish myself for the bad info.I feel so dirty.
Simple question.
Quote from: vinnietbird;206438
The earlier (83-85) are the same as the Mustangs, the later (86-88) are not. ;)
Simple question.
Aaaaah,Now I will remember that....forever !!!!!
