Topic: $5 horn button repair (Read 1133 times) previous topic - next topic
I wanted a reasonable way to repair (two) broken horn buttons.  It took a couple of tries to fine-tune it.
__________________
Twin '85 TCs
White/ Grey 2-tone
Here are the supplies:
One adjustment - I ditched the nylon screws for metal.
Parts:
6-32 x 3/4" machine screw
6-32 x 1/4" T-nut
#6 nut
#6 washer
#6 flat speed washer
__________________
Twin '85 TCs
White/ Grey 2-tone
How to use them:
Use a dremel or hobby knife to make a notch big enough for the T-nut to fit.  Clear any remainder of the broken tab.
Use a cutting wheel, tin snips, or wire cutter to trim the T-nut as shown ("after" to the left, "before" to the right)
Final assembly.  Use a washer, nut and a spacer to clamp the T-nut to the plastic.
You might need to trim the flat speed nut to clear properly.
__________________
Twin '85 TCs
White/ Grey 2-tone
