Topic: Front suspension upgrade ideas (Read 1763 times) previous topic - next topic
Ok, I'm doing a little "long term planning" (dreaming) here, and want to make sure I cover everything.  I want to go with 94-95 Mustang spindles and the FRPP control arms.  Now, the cup spring is 1/2 inch lower.  Will this make my caster camber off?  Wouldn't it have the same effect as lowering springs?
Second, I'm going with the 98+ brakes.  I'm thinking these should bolt right up, cause I saw nothing to the contrary on CoolCats or some Mustang forums.  Just want to double check.  Has anyone done this?
351W in the works
Quote from: bhazard;300566
You got woman'd.
Search link?
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
You'll want CC plates if you're going to go to the trouble of swapping arms.  You'll want an alignment in any case.  In other words, don't worry about it.
__________________
Twin '85 TCs
White/ Grey 2-tone
http://www.coolcats.net/tech/advanced/4to5lug.html
I was using this as my main source.  Not much luck on the other forums.
I figured the CC plates would be a good idea, for future plans and such, but I was trying to keep this somewhat cheap.  Gotta pay to play, I guess.
351W in the works
You got woman'd.
Quote from: t3skidoo;205179
The FRPP arms will be the same length as his current ones.
Yep, the new arms will be pretty much like the ones you have now. The SN95 spindles will require SN95 ball joints. Otherwise, if you're not lowering the car any, I don't see why c/c plates would be required.
Running the 1998-2004 Mustang braking system will be just fine.
