Poll
witch moter?
Total Members Voted: 39
Topic: 4bangen no more? (Read 5432 times) previous topic - next topic
4bangen no more?
1. Obtain Mark VIII 4.6 DOHC
2. Install forged pistons and rods, maybe oil pump gears, nothing else, parts cost around 1500 total probably
3. Twin turbo
4. 600 HP at 15 psi
5. ???
6. Profit
If going with a Windsor series and you want 600 HP one day, just forget the 302 based and go with a 351 block.  From what I know the 347, although better than early iterations, still uses a tight ring pack and the pin intersects the oil ring, short piston to get any decent rod length, etc.  A 331 would still be less risky I think.
If you really just want 400 hp, that's already been proven by many with the 2.3, doesn't take a lot of drama to get there, just lots of boost and a good tune.  That compared with a 400 HP V8 is certainly a different animal though, but either one will go fast and if the 2.3 pops it's cheap to fix and replace.
It would be absurd to put some other (non-bolt-in) engine in there unless you like spending big bucks (or lots of time) just to be different, custom engine mounts and transmission setup.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
4bangen no more?
Whats the resipey for a 400hp 2.3t? If I kept it, I was planning ported head big valves, gutted and rotated intake, I have a massive FMIC for it, holset turbo with stinger tube header, 3" exaust, and a M.S. programer that does away with the vam. Top it all off with a 100hp wet shot. What would that net me?
Quote from: jlewis05;203919
3. Twin turbo
4. 600 HP at 15 psi
5. ???
6. Profit
4bangen no more?
5. ???
6. Profit
Oh and by the way.....lol:D
4bangen no more?
The 331 is only risky if the engine assembler screws up.
The rings issues are moot.
4bangen no more?
I suppose it depends on the RPM you plan on turning, I like a lot :D.  You know where to look for the 2.3 recipes, on Turboford, porting and big valves with the right turbo should be the main ingredients.  Wes Kiser turned numbers around that with what seemed to be a fairly straightforward setup, of course he's an engineer by trade I think :D.
84 SVO
88 TC
87 XR4Ti
4bangen no more?
i'm more of a 2.3t so you know how i voted. like said before keep it 2.3t if you want the v8 power buy a car that came with one. it is your car so do what you want. also if you smoked your clutch way not just install a new one
4bangen no more?
What kind of proformance clutches are there for the 2.3?
4bangen no more?
Hehe, there's anything you want.  You can get a puck clutch that will grab like there's no tomorrow but it'll be harder to drive, clutchnet.com, the more pucks the smoother it will be and the less power handling, less pucks means more power handling, grabbier engagement.  A six puck would probably be driveable with an iron flywheel but not with aluminum, I have one with aluminum and it's a pain to take off but I'm cool with that.  For something that drives completely like stock clutchnet and spec make composite friction materials for discs.  A stock PP would probably be fine for you if you run an aggressive disc.
84 SVO
88 TC
87 XR4Ti
4bangen no more?
The CHP 347 kit does not have the oil rings in wrist pin if that is a concern.....
http://www.foxtbirdcougarforums.com/showthread.php?t=8479&highlight=331+347
4bangen no more?
Yeah, I thought someone finally made the stack short and high enough to stay out of the wrist pin, guess that's it.
84 SVO
88 TC
87 XR4Ti
4bangen no more?
It uses the 331 piston.....1.175" CH as opposed to 1.09".
4bangen no more?
Desition made! 2.3l stays. Well actualy its coming out, but a fully built 2.3 is going back in! he he he
4bangen no more?
4. 600 HP at 15 psi
5. ???
6. Profit
Hey whats phase 5?
"I duno, phase 6 is profit!"
LMFAO
4bangen no more?
Step 1 :  Collect Underpants!
4bangen no more?
Quote from: 4bangen;204249
Woot woot, a victory in the 2.3 vs 5.0 battle!
