Topic: what springs and controle arms are you runing (Read 1385 times) previous topic - next topic
when i install my lincoln rear im thinking of replaceing the controle arms and springs ...what should i use ...id like to have a bit of a rake but not to much,,id like to have a really agressive stance....when i done the front  i used struts from 95 gt but still have the stock springs.....
Im using stock control arms in the rear with spherical bearing on the chassis side of the lowers with urethain bushings on the rear. uppers have urethain on the chassis side as well but have been shortened to increase the pinion angle.
I run CHE fixed length control arms and Eibach drag springs
