Topic: need a shaker scoop (Read 2996 times) previous topic - next topic
need a shaker scoop
this may be a dumb question, but where can i find a shaker scoop to fit my 95 cougar?
It's always fun until someone loses an eye. then it's fun ya can't see.
-James Hetfield back when metallica was still making good music.
need a shaker scoop
No one makes one.
need a shaker scoop
yep. that will have to be custom. shouldnt be terribly difficult though. love the shaker. buy the center section of a mach 1 hood and the shaker setup. make some brackets to mount the shaker plenum. find a fiberglass hood for your car and patch in the fiberglass mach 1 hood center.
~John~
need a shaker scoop
I have the answer you need.On Ebay Australia,there are shaker assemblies,they are $447.00 U.S. for the setup with the "buy it now".It seems like a lot,but,compared to what the shaker hood scoop setup for a Fox Stang setup costs (about $800.00),it's not so bad.I'll try to find an item number for you.
need a shaker scoop
O.K.,check these two item numbers out......
110222047587
300196524639
Awesome stuff !!!!!!!
need a shaker scoop
ALMOST what i'm looking for. it's a good scoop, but the air tube is all wrong. with a 94/95, i'd need the air tube to go straight back. could k&n make them or are they only filters? are there universal setups for shakers?
need a shaker scoop
Good luck.For one of these,it wouldn't be hard to move the tube.K&N doesn't have them.They are really hard to find.
need a shaker scoop
What about a Mach 1 setup from a couple of years ago?they are on Ebay quite often.
need a shaker scoop
got a pick?
need a shaker scoop
here's the item number I found.270208793093.It comes with the hood,but if you wanted it bad enough,perhaps he'd deal with you .
need a shaker scoop
would it be easier/ cheaper to get one of the 99 mustang shakers or get a scoop, make a box with a black plastic sheet and k&n filter and fit it like your 2.3 turbo air filters? that way i'd have a choice of scoops and it'd easier to find. price tags on that mustang shaker are a little more than i had in mind.
need a shaker scoop
I haven't seen a cheap scoop even by itself.Thay are obviously worth their weight in cash.
need a shaker scoop
i think i'll try the 2.3 turbo's air filter setup (seals to the hood) with a scoop instead. shaker would be nice, but too pricy.
need a shaker scoop
The filter doesn't seal to the hood,the intercooler does.Sorry if that's a set back.
need a shaker scoop
oh. well it looks like an air filter. guess i can just use my gallon bucket-sized k&n and a scoop. much easier.
